Discovery SpaceClaim: Reverse Engineering/Modeling – Build a Solid by Extracting Curves from a Scan STL, Part 2
November 2, 2022 at 9:17 am
Solution
ParticipantThis video demonstrates how to construct a model from a scanned surfboard. Instead of manually sketching over the scan, you will extract curves from the scan and them blend to create the more organic model. (Part 2 of 2)
- Surface to solid creation in SpaceClaim
- FAQ – Share Topology is now available in Discovery 2021 R2
- Changing the visibility of bodies from transparent to opaque or vice-versa
- Ansys Discovery – Working with Components
- Discovery Quick Tip- How to update your geometry from a source CAD File
- Quick Tips for Volume extraction in SpaceClaim
- Ansys Discovery: Automatic External Volume Enclosure
- Split Face in SpaceClaim
- Selecting all inner faces of a body
- Stitch Faces & Split Edges Tools in SpaceClaim
