Discovery SpaceClaim: Reverse Engineering/Modeling – Build a Solid by Extracting Curves from a Scan STL – Part 1
November 2, 2022 at 9:17 am
SolutionParticipantThis video demonstrates how to construct a model from a scanned surfboard. Instead of manually sketching over the scan, you will extract curves from the scan and them blend to create the more organic model. (Part 1 of 2)
- Surface to solid creation in SpaceClaim
- FAQ – Share Topology is now available in Discovery 2021 R2
- Split Face in SpaceClaim
- Ansys Discovery – Working with Components
- Selecting all inner faces of a body
- Discovery Quick Tip- How to update your geometry from a source CAD File
- Changing the visibility of bodies from transparent to opaque or vice-versa
- Ansys Discovery for Geometry Preparation
- Quick Tips for Volume extraction in SpaceClaim
- Ansys Discovery – Detect Tool
