Tagged: Extract Curves, stl, STL Orient, STL Skin Surface
November 11, 2022 at 10:40 am
Watch & LearnParticipant1) STL Selection with SpaceClaim
Learn how to apply standard selection techniques to Meshes and STL files, an learn some techniques and tips that are specific to mesh/STL files.
2) Orienting STL Mesh in SpaceClaim
This video demonstrates how to orient a scan/mesh/STL to world origin. It shows a couple of different ways to orient the mesh. Some of the tools have moved to the Tools Tab Reverse Engineering
3) Building Solids with STL Files in SpaceClaim
This video demonstrates the basics of model creation in the context of an STL file. It shows manual sketching method, which often results in the cleanest geometry.
4) Advanced Patching & Options in SpaceClaim – Part 1
This video demonstrates some advanced patching techniques using the Skin Surface tool. It shows how to join up different types of patches, and take a deep look into the options associated with the tool. (Part 1 of 2)
5) Advanced Patching & Options in SpaceClaim – Part 2
This video demonstrates some advanced patching techniques using the Skin Surface tool. It shows how to join up different types of patches, and take a deep look into the options associated with the tool. (Part 2 of 2)
6) Build a Solid by Extracting Curves from a Scan STL – Part 1
This video demonstrates how to construct a model from a scanned surfboard. Instead of manually sketching over the scan, you will extract curves from the scan and them blend to create the more organic model. (Part 1 of 2)
7) Build a Solid by Extracting Curves from a Scan STL – Part 2
This video demonstrates how to construct a model from a scanned surfboard. Instead of manually sketching over the scan, you will extract curves from the scan and them blend to create the more organic model. (Part 2 of 2)
8) Creating Boundary Patches from STL in SpaceClaim
This video demonstrates how to use the Skin Surface tool to wrap spline surfaces onto an STL, OBJ or other importable mesh files. It focuses on the boundary patch method.
9) Creating Periodic Blended Patches from STL in SpaceClaim
This video demonstrates how to use the Skin Surface tool to create blended spline surfaces onto an STL, OBJ or other importable mesh files. It focuses on the periodic patch method, which creates surfaces between closes boundaries around the circumference of a section of an STL.
- Surface to solid creation in SpaceClaim
- Ansys Discovery – Detect Tool
- Ansys Discovery – Working with Components
- Changing the visibility of bodies from transparent to opaque or vice-versa
- Discovery Quick Tip- How to update your geometry from a source CAD File
- FAQ – Share Topology is now available in Discovery 2021 R2
- Selecting all inner faces of a body
- Split Face in SpaceClaim
- Quick Tips for Volume extraction in SpaceClaim
- Stitch Faces & Split Edges Tools in SpaceClaim
