November 2, 2022 at 9:17 am
Solution
ParticipantCFD analysis requires internal or external flow volume. This video demonstrates a technique using standard modeling tools to create a fluid domain when the geometry does not allow for the Volume Extract or Enclosure tools to create a good volume.
- Surface to solid creation in SpaceClaim
- Ansys Discovery – Working with Components
- FAQ – Share Topology is now available in Discovery 2021 R2
- Changing the visibility of bodies from transparent to opaque or vice-versa
- Discovery Quick Tip- How to update your geometry from a source CAD File
- Selecting all inner faces of a body
- Split Face in SpaceClaim
- Quick Tips for Volume extraction in SpaceClaim
- Stitch Faces & Split Edges Tools in SpaceClaim
- Ansys Discovery: Automatic External Volume Enclosure
