November 11, 2022 at 10:40 am
SolutionParticipant1) Discovery SpaceClaim: Model Prep for CAE & MFG – Simplify and Defeature in SpaceClaim – Part 1
This video demonstrates simplify and defeaturing process in SpaceClaim. It shows how to simplify and defeature a model by removing faces, holes, rounds etc. with the Fill Tool.
2) Discovery SpaceClaim: Model Prep for CAE & MFG – Simplify and Defeature Part 2
This video demonstrates simplify and defeaturing process in SpaceClaim. It shows how to simplify and defeature a shaft by removing small faces and teeth with the Fill tool.
3) Discovery SpaceClaim: Model Prep for CAE & MFG – Round Removal
This video demonstrates removal of rounds in SpaceClaim. It shows the use of “Round tool” which is designed specifically for selecting and removing rounds.
4) Discovery SpaceClaim: Model Prep for CAE & MFG – Splitting and Imprinting Faces
This video demonstrates splitting and imprinting of faces in SpaceClaim. It shows use of Split Face tool and Imprint tool and the options associated with these tools.
5) Discovery SpaceClaim: Model Prep for CAE & MFG – Merge Faces, Small Faces
This video demonstrates Merge face tool and Small Faces tool in SpaceClaim. It shows how to identify small faces and merge faces using these tools and clean the model.
6) Discovery SpaceClaim: Model Prep for CAE & MFG – Partitioning a Solid into Multiple Bodies
This video demonstrates splitting solid of or partitioning solid in SpaceClaim. It shows the use of Split Solid tool and Combine tool for splitting model as per requirement.
7) Discovery SpaceClaim: Model Prep for CAE & MFG – Driving Dimensions & Named Selections
This video demonstrates creation of driving dimensions in SpaceClaim. It shows how to create groups and annotations to drive a design for optimization.
8) Discovery SpaceClaim: Model Prep for CAE & MFG – Repair
This video demonstrates importing and repairing operations in SpaceClaim. It shows how to clean up corrupt 3D data using different repair tools.
9) Discovery SpaceClaim: Model Prep for CAE & MFG – Manual Midsurface & Shell Extraction
In SpaceClaim, Midsurface can be extracted automatically or manually. This video demonstrates the manual process and the options associated with midsurface tool.
10) Discovery SpaceClaim: Model Prep for CAE & MFG – Automatic Midsurface & Shell Extraction
In SpaceClaim, Midsurface can be extracted automatically or manually. This video demonstrates the automatic process and the options associated with midsurface tool.
11) Discovery SpaceClaim: Model Prep for CAE & MFG – Internal CFD/Core Volume Extraction
CFD analysis requires internal or external flow volume. This video demonstrates how to create external flow volume i.e. enclosure in SpaceClaim.
12) Discovery SpaceClaim: Model Prep for CAE & MFG – Automatic External Volume Enclosure
CFD analysis requires internal or external flow volume. This video demonstrates how to create external flow volume i.e enclosure in SpaceClaim.
13) Discovery SpaceClaim: Model Prep for CAE & MFG – Manual Fluid Body Creation
CFD analysis requires internal or external flow volume. This video demonstrates a technique using standard modeling tools to create a fluid domain when the geometry does not allow for the Volume Extract or Enclosure tools to create a good volume.
14) Discovery SpaceClaim: Model Prep for CAE & MFG – Weld Surface Creation Tool
This video shows how to use the Weld Tool to create new weld surfaces between midsurface and shell bodies that cannot be extended. Extending surfaces to intersect with each other is often the optimal way to create a conformal mesh. When the midsurface shells cannot be extended properly, the Weld Tool is used to join the bodies correctly.
15) Discovery SpaceClaim: Model Prep for CAE & MFG -Beam Extraction
This video shows how to import a solid model and extract beam elements and profiles. It shows how to clean up connections, extend, trim and connect beams and split intersections.
16) Discovery SpaceClaim: Model Prep for CAE & MFG – Create Simplified Structural Solid
This video demonstrates creation of a simplified structural geometry. It shows how to create a simplified model instead of simplifying the actual geometry.
17) Discovery SpaceClaim: Model Prep for CAE & MFG – Scripting (Beta)
Scripting is supported in SpaceClaim. This video shows how to record and replay commands in Script editor.
- Surface to solid creation in SpaceClaim
- Ansys Discovery – Detect Tool
- Ansys Discovery – Working with Components
- Changing the visibility of bodies from transparent to opaque or vice-versa
- Discovery Quick Tip- How to update your geometry from a source CAD File
- FAQ – Share Topology is now available in Discovery 2021 R2
- Selecting all inner faces of a body
- Split Face in SpaceClaim
- Quick Tips for Volume extraction in SpaceClaim
- Stitch Faces & Split Edges Tools in SpaceClaim
