Discovery SpaceClaim: Geometry Repair – SpaceClaim Advanced Repair – ReCreating Multiple Missing Faces
November 2, 2022 at 9:17 am
Solution
ParticipantSome models from other CAD systems import with multiple missing faces in a single areas. Sometimes the missing faces tool cannot handle replacing so many missing faces in 1 spot. This video shows how to use the Blend and Fill Patch Blend to manually build edges and faces to replace multiple missing faces.
- Surface to solid creation in SpaceClaim
- FAQ – Share Topology is now available in Discovery 2021 R2
- Ansys Discovery – Working with Components
- Changing the visibility of bodies from transparent to opaque or vice-versa
- Discovery Quick Tip- How to update your geometry from a source CAD File
- Selecting all inner faces of a body
- Split Face in SpaceClaim
- Quick Tips for Volume extraction in SpaceClaim
- Ansys Discovery: Automatic External Volume Enclosure
- Stitch Faces & Split Edges Tools in SpaceClaim
