November 2, 2022 at 9:17 am
SolutionParticipantSome models from other CAD systems import with sketch entities like line, arc and splines that need repair. Sometimes there are gaps between the ends of the sketches, or we need to fit new sketch entities to existing ones. There may also be small curves or duplicates that need to be removed. This video shows using the Sketch Repair Tools: Fit Curves, Curve Gaps, Duplicate Curves and Small Curves to clean up a sketch.
- Surface to solid creation in SpaceClaim
- Split Face in SpaceClaim
- FAQ – Share Topology is now available in Discovery 2021 R2
- Ansys Discovery – Working with Components
- Selecting all inner faces of a body
- Discovery Quick Tip- How to update your geometry from a source CAD File
- Changing the visibility of bodies from transparent to opaque or vice-versa
- Ansys Discovery for Geometry Preparation
- Quick Tips for Volume extraction in SpaceClaim
- Ansys Discovery – Detect Tool
