September 26, 2022 at 10:15 am
SolutionParticipantDiscovery Refine: Results fail to appear after solve in Refine stage.
Problem: For small cases, results are expected to appear within 10-20 seconds of solving in the Refine stage. If Intel OpenCL drivers are installed on your system and results fail to appear regardless of how long you wait, the problem may be due to a bad driver installation.
Solution: To determine whether a bad driver installation is the problem, run this command:
<ansys-install-location>/Framework/bin/Win64/Ans.DriverSetup.exe –verbose –check- opencl -availability
If your system is set up correctly, the following message appears, followed by one or more entries for the hardware that was found:
Found OpenCL Platforms:On a problematic system, the following message appears:
OpenCL Check: Ans.DriverSetup.exe resulted in an unhandled error.To correct a problematic system, you must remove any installed Intel drivers completely and reinstall them directly from the Intel web site. The bad Intel drivers will interfere with the display of solution results regardless of whether you set the system to use NVIDIA or AMD GPUs.
Ansys has used the following process to correct the problem on some customer systems:
- From http://www.intel.com, download the driver for your Intel GPU.
- Use Add or remove programs to remove completely all instances of programs with Intel and OpenCL in their names.
- Disconnect your system from the internet.
- Ensure your internet will not reconnect automatically.Doing so ensures that Windows update cannot reinstall a bad driver.
- From Device Manager, find Intel Graphics and select Action > Uninstall device.
- Reboot.
- Install the Intel driver you downloaded in step 1.
- Reboot.
- Run
Ans.DriverSetup.exeto verify that the symptom is cleared. - Reconnect your system to the internet.
- In Discovery, re-solve and attempt to view results.
For additional details about deleting Intel drivers completely, see https://www.intel.co.uk/content/www/uk/en/support/articles/000057389/graphics.html.
- In-Depth – Fluids Simulation using Ansys Discovery
- Discovery: Porous media coefficient calculator
- Ansys Discovery: Topology Optimization
- Discovery – Defining new material
- Structural Simulation using Bolt Idealization
- Thermal Analysis of Heat Sinks with Ansys Discovery
- Discovery Quick Tip- Understanding Contour Settings
- How to apply bolt Pretension in ANSYS Discovery?
- Discovery Quick Tip- How to Export to Fluent
- Discovery Explore: How to retain a certain portion of the geometry in topology optimization?
