September 26, 2022 at 10:15 am
FAQParticipantIn Discovery Analyze mode, the simulation is performed using High fidelity solvers which require mesh in the computational domain.
When you click the Solve button, the physics region is meshed as per the mesh settings defined.
To view the generated mesh, you need to click “Show Mesh” button located near the Solve button in Results Arc. See below snapshot.
However, you won’t see the generated mesh immediately when you click the Show Mesh button. Once the simulation proceeds beyond 50%, the mesh becomes visible. The progress of the simulation can be seen in the Simulation Information Display (SID). When more than 50% of the hexagon boundary becomes green color, the generated mesh gets displayed in the geometry. See below snapshot.
- In-Depth – Fluids Simulation using Ansys Discovery
- Discovery: Porous media coefficient calculator
- Symmetry Boundary condition for Fluid flow simulation in Ansys Discovery
- Discovery – Defining new material
- Ansys Discovery: Topology Optimization
- Discovery Quick Tip- Understanding Contour Settings
- How to apply bolt Pretension in ANSYS Discovery?
- Discovery Quick Tip- How to Export to Fluent
- Structural Simulation using Bolt Idealization
- Discovery Quick Tip- Applying Thermal Conductance
