September 26, 2022 at 10:15 am
FAQ
ParticipantDiscovery Refine Mode – Defining number of boundary layers
Currently, there is no option to specify the number of boundary layers to be generated. But, they can be controlled to some extent using the fidelity slider. At the low end of the Fidelity slider, three boundary layers are specified, at the high end of the slider seven layers, and in the middle of the slider five.
If you combine a local fidelity adjustment setting with the fidelity slider, you will get mesh as shown above.
With the fidelity slider at the lowest position :
With the fidelity slider at the middle position :
With the fidelity slider at the highest position:
- In-Depth – Fluids Simulation using Ansys Discovery
- Discovery: Porous media coefficient calculator
- Structural Simulation using Bolt Idealization
- Ansys Discovery: Topology Optimization
- Thermal Analysis of Heat Sinks with Ansys Discovery
- Discovery – Defining new material
- How to apply bolt Pretension in ANSYS Discovery?
- Ansys Discovery- Intake and Exhaust Fan for Fluids
- Discovery Explore: How to retain a certain portion of the geometry in topology optimization?
- Discovery Quick Tip- Understanding Contour Settings
