May 14, 2023 at 7:51 am
Watch & LearnParticipantIn this quick tip video, we will see how you can use contour settings in Discovery post processing efficiently.
Result contours in Ansys Discovery are a powerful feature that allows you to visualize various results on your simulation model. The result contours button is conveniently located at the top of the result arc and the bottom right-hand corner of the screen. When you activate this button, it highlights in blue, and a legend appears to help you interpret the displayed data. For different visualization controls, you can mouse over the contours icon to access a pop-up window where you can adjust settings like the location or display of the result contours. Result contours in Ansys Discovery are a powerful feature that allows you to visualize various results on your simulation model. The result contours button is conveniently located at the top of the result arc and the bottom right-hand corner of the screen. When you activate this button, it highlights in blue, and a legend appears to help you interpret the displayed data. For different visualization controls, you can mouse over the contours icon to access a pop-up window where you can adjust settings like the location or display of the result contours.
- In-Depth – Fluids Simulation using Ansys Discovery
- Discovery: Porous media coefficient calculator
- Symmetry Boundary condition for Fluid flow simulation in Ansys Discovery
- Discovery – Defining new material
- Ansys Discovery: Topology Optimization
- Discovery Quick Tip- Understanding Contour Settings
- How to apply bolt Pretension in ANSYS Discovery?
- Structural Simulation using Bolt Idealization
- Discovery Quick Tip- How to Export to Fluent
- Thermal Analysis of Heat Sinks with Ansys Discovery
