Tagged: Additional Fluid Flow Options, CPU solvers, default solver, fluid simulations, fluid-thermal simulations, GPU memory, GPU memory guideline, GPU resources, GPU solver technology, graphics card resources, LiveGX solver, mass-flow, pressure-drop, quick solution, refine, Refine panel, simulation options, Simulation tab ribbon, system RAM
November 16, 2023 at 5:52 am
Watch & Learn
ParticipantIn this quick tip video, we will see how you can use LiveGX solver in Discovery Refine stage. This video features 2023R1, although in the latest release of Discovery 2024R1 and onwards, the LiveGX solver is the default solver for refine stage.
The LiveGx solver is accessible under Simulation Options in the Simulation tab ribbon. Click Additional Fluid Flow Options (Refine) to see the options in the expanded panel. GPU and CPU are available with Use LiveGX solver.
Note: The LiveGX solver uses a different wall distance algorithm when run using CPU or GPU. This difference may result in slight variations in convergence behavior and results between a CPU and a GPU solution.
Please refer to this documentation to understand the feature in detail: Fluid Flow LiveGX SolverÂ
Please refer to this documentation to understand the license requirements for LiveGX solver: Fluids Physics Licensing
- In-Depth – Fluids Simulation using Ansys Discovery
- Discovery: Porous media coefficient calculator
- Structural Simulation using Bolt Idealization
- Ansys Discovery: Topology Optimization
- Thermal Analysis of Heat Sinks with Ansys Discovery
- Discovery – Defining new material
- How to apply bolt Pretension in ANSYS Discovery?
- Discovery Quick Tip- Understanding Contour Settings
- Ansys Discovery- Intake and Exhaust Fan for Fluids
- Discovery Explore: How to retain a certain portion of the geometry in topology optimization?
