May 14, 2023 at 8:17 am
Watch & LearnParticipantIn this video you will see how you can change the boundary condition locations, in an already defined boundary condition.
The process outlined in this video is as follows:
1. Navigate to the physics tree within your project.
2. Right-click on the boundary condition you wish to modify and choose “Replace Location.”
3. Select the new surface or location where you want to apply the boundary condition.
4. Hit the escape key a few times to exit the selection mode.
5. Click to solve your simulation again to see the effects of the updated boundary condition on your results.
- In-Depth – Fluids Simulation using Ansys Discovery
- Discovery: Porous media coefficient calculator
- Discovery – Defining new material
- Symmetry Boundary condition for Fluid flow simulation in Ansys Discovery
- Ansys Discovery: Topology Optimization
- Discovery Quick Tip- Understanding Contour Settings
- How to apply bolt Pretension in ANSYS Discovery?
- Structural Simulation using Bolt Idealization
- Thermal Analysis of Heat Sinks with Ansys Discovery
- Discovery Quick Tip- How to Export to Fluent
