Tagged: cylindrical body, discovery, fans, fluid-flow, heat-transfer, impellers, inertial reference frame, Mixing Tanks, moving parts, moving reference frame, moving reference frame model, mrf, non-inertial reference frame, rotating blades, stationary reference frame, steady-state problem, unsteady problem
December 16, 2023 at 6:19 am
Watch & LearnParticipantDiscovery generally solves the equations of fluid flow and heat transfer in a stationary (or inertial) reference frame. However, there are many problems where the equations might need to be solved in a moving (or non-inertial) reference frame. For example, fans and mixing tanks with their rotating blades, impellers, and similar objects (comprising a cylindrical body and blades) cause the fluid around those parts to flow with some rotation. In most cases, the moving parts render the problem unsteady when viewed from the stationary frame. However, the flow around the moving part can (with certain restrictions) be modeled as a steady-state problem with respect to the moving frame.
In this quick tip video, we will see how you can apply rotating fluid zone in Discovery.
Refer this documentation to understand this better: Rotating Fluid ZonesÂ
- In-Depth – Fluids Simulation using Ansys Discovery
- Discovery: Porous media coefficient calculator
- Ansys Discovery: Topology Optimization
- Discovery – Defining new material
- Discovery Quick Tip- Understanding Contour Settings
- Structural Simulation using Bolt Idealization
- Thermal Analysis of Heat Sinks with Ansys Discovery
- How to apply bolt Pretension in ANSYS Discovery?
- Discovery Quick Tip- How to Export to Fluent
- Symmetry Boundary condition for Fluid flow simulation in Ansys Discovery
