September 26, 2022 at 10:15 am
FAQParticipantPorous conditions can be used to model a wide variety of applications, such as fluid flow through filters, packed beds, perforated plates, flow distributors, and tube banks. The porous medium is modeled as a momentum loss, the magnitude of which involves resistance coefficients.
Porous media condition can be used in Explore as well as Refine mode.
Si=-(µ/α vi + ½ C2ρ|v|vi)
where
Si is the momentum source which accounts for the porous loss
C2 is the inertial resistance
α is the permeability
μ is the fluid viscosity
ρ is the fluid density
|v| is the velocity magnitude
vi is the velocity vector of the ith component in the medium
For low-Reynolds number flows, the viscous loss typically dominates, and the inertial resistance coefficient can often be set to 0. For turbulent flows, the inertial loss typically dominates, and the viscous resistance coefficient can often be set to 0.
If you have experimental tabulated data of pressure drop as a function of velocity for a porous medium of thickness Δx, you can derive the resistance coefficients:
ΔP/Δx = -(µ/α v + ½ C2ρv2)
This document provides a guide on how to calculate and define the resistance coefficients using a script or spreadsheet calculator for isotropic porous media in ANSYS Discovery.
Please use attached discovery script to automatically calculate the porous media coefficients and apply them. While a more comprehensive tool is under development, with the attached tool, you can calculate the isotropic porous media coefficient, that is Inertial and Viscous resistance in the streamline direction.
- In-Depth – Fluids Simulation using Ansys Discovery
- Discovery: Porous media coefficient calculator
- Symmetry Boundary condition for Fluid flow simulation in Ansys Discovery
- Discovery – Defining new material
- Ansys Discovery: Topology Optimization
- Discovery Quick Tip- Understanding Contour Settings
- How to apply bolt Pretension in ANSYS Discovery?
- Structural Simulation using Bolt Idealization
- Discovery Quick Tip- How to Export to Fluent
- Thermal Analysis of Heat Sinks with Ansys Discovery
