Tagged: Analyze-FAQ, Ansys Discovery, Application Example, Explore-FAQ, thermal
September 26, 2022 at 10:15 am
FAQParticipantDownload the file here
Application example of a heat sink utilizing Discovery Explore’s parametric study tool to explore multiple design configurations and the best possible design point is then simulated in Discovery Analyze. The following images show the temperature distribution in one of the representative design points, and temperature distribution in analyze mode. This project requires release 2020 R2 or newer.
- In-Depth – Fluids Simulation using Ansys Discovery
- Discovery: Porous media coefficient calculator
- Discovery – Defining new material
- Symmetry Boundary condition for Fluid flow simulation in Ansys Discovery
- Ansys Discovery: Topology Optimization
- Discovery Quick Tip- Understanding Contour Settings
- How to apply bolt Pretension in ANSYS Discovery?
- Structural Simulation using Bolt Idealization
- Thermal Analysis of Heat Sinks with Ansys Discovery
- Discovery Quick Tip- How to Export to Fluent
