April 5, 2023 at 2:32 pm
FAQ
ParticipantProblem: If Discovery Live is installed on a network drive, it is observed that the application crashes or user cannot perform operations like selecting faces during enclosure creation in fluid flow setup and so on. Cause: This may happen due to one of the xml files not getting copied from network drive to local drive Recommended solution: To overcome the above mentioned problem, copy file named “MaterialLibrary.xml” from ~
Ansysv191scdmMaterialLibrary to %AppData%RoamingSpaceClaimDiscoveryMaterialLibrary
- Q: How do I set the license server from my client machine?
