May 15, 2023 at 8:33 am
SolutionParticipantCheck out below video highlighting improvements and enhancements to Discovery Live in ANSYS 19.2. One major enhancement is the further automation between design iterations and simulations, which are even easier because of the addition of parametric studies. Now you can explore a large number of design possibilities by varying multiple geometric or simulation parameters. By interactively determining optimized values and better understanding tradeoffs and trends, you can select the best design for your needs. Other enhancements and improvements we’ll show you include: Support for visibility layers and custom views Volumetric heat generation Exporting calculator results Default units improvements Updating source file from non-native CAD file Many new boundary conditions to accurately define simulations
1. 2057159.mp4
- Skewness in ANSYS Meshing
