Discovery Live: I have a machine with several graphics cards. How do we know which card the software will target?
April 5, 2023 at 2:32 pm
FAQ
ParticipantGo into the NVIDIA Control Panel (i.e. right click on your PC desktop, or through Windows search option). Then go to “Manage 3D settings” There will be 2 tabs, “Global settings” and “Program settings” Go to “Program settings”, and if Discovery Live is not listed, Click Add. If its not in that list, go to Browse and find the executable in your install directory. The 2nd drop down should be a list of your cards, choose the one and click Apply.
