Tagged: 19, ANSYS SpaceClaim DirectModeler, fluid-dynamics, General
May 15, 2023 at 8:33 am
SolutionParticipantTo get an average or mean value of chart results, left click inside the chart and drag the cursor inside the chart area. You can also enable “Time Average” option. Please check attached solution for detailed information.
1. 2053666.pdf
- Skewness in ANSYS Meshing
