General
General
Discovery Live: How to define input mass flow rate instead of velocity in internal flow simulations?
    • FAQFAQ
      Participant
      Discovery Live currently does not support this feature. You could work around this limitation by manually calculating the equivalent velocity as: (Inlet velocity magnitude) = (mass flow rate) / {(Density of fluid) * (Area of inlet face)} The area of the inlet face can be obtained using the Measure tool from Measure tab.
