May 15, 2023 at 8:33 am
Solution
ParticipantGo to File – Live Options – Units and under “Type” option you can select either Imperial or Metric unit system. Please attached image which shows this option. You can also set the unit system for current document and all new documents through “Unit Settings for” option located at the top.
- Skewness in ANSYS Meshing
