August 8, 2023 at 10:15 am
FAQ
ParticipantPlease find below the steps to create a monitor on a point:
1. First, you need to create a point at the required location. For example, we want to create a point on the end face of the bracket example shown below.
2. Go to Design menu and click Point tool
3. Click on the face to create a point.
4. Now go to Simulation menu and add a new Monitor.
5. Select the newly created point and from the Variables drop down list, select Displacement.
6. Select appropriate magnitude option (min, max or average) and click the green check to complete the operation. You will see a monitor chart created for the selected point.
7. Once you solve the simulation, you will see the calculated value on the monitor chart.
- In-Depth – Fluids Simulation using Ansys Discovery
- Discovery: Porous media coefficient calculator
- Structural Simulation using Bolt Idealization
- Ansys Discovery: Topology Optimization
- Thermal Analysis of Heat Sinks with Ansys Discovery
- Ansys Discovery- Intake and Exhaust Fan for Fluids
- Discovery – Defining new material
- How to apply bolt Pretension in ANSYS Discovery?
- Discovery Explore: How to retain a certain portion of the geometry in topology optimization?
- Discovery Quick Tip- Understanding Contour Settings
