April 5, 2023 at 2:32 pm
FAQParticipantProblem: With Discovery Enterprise license, following warning message may appear: WARNING: Licensing files currently installed are more recent than those on the installation media. The files will not be installed and will be deselected…. Cause: The installation of Discovery Enterprise contains some newer .exe files than the license manager installation. This causes the error seen. Recommended solution: To fix this issue, Delete or rename the existing ‘Shared FilesLicensinglicadmindocuabout.licadmin’ file, usually located within C:Program FilesAnsys Inc. Then try reinstalling the updated License Manager.
