April 5, 2023 at 2:32 pm
FAQParticipantWhat is Discovery Enterprise License? – Discovery Enterprise license is similar to the traditional ANSYS floating license. – This license is for use by customers who cannot utilize cloud-based subscription licensing for Discovery products. Reasons for this may include firewall constraints or data privacy concerns. – This license has the same capabilities as the standard version of ANSYS Discovery 19.1. How to get Discovery Enterprise Evaluation license? – Contact your ANSYS Sales Administrator for Discovery Enterprise Evaluation license. – The license file will be sent to you via email. This email will also have a pdf document attached with instructions for downloading and installing the software. Does Discovery Enterprise Evaluation license require a different installer? – Yes, Discovery Enterprise Evaluation license requires a different installer. The subscription based installer available under Downloads page will not work with Enterprise license. – Instructions for downloading and installing the software are attached in the mail having the license file. – You can also access these instructions in solution 2056174.
