September 26, 2022 at 10:15 am
SolutionParticipantIn Refine mode of Ansys Discovery, the default Turbulence model used is K-Omega SST.
To change the Turbulence model, go to Simulation Menu and click Simulation options.
Under Additional Fluid Flow Options, click Specify modeling method
You can now select the turbulence model from the available list.
- In-Depth – Fluids Simulation using Ansys Discovery
- Discovery: Porous media coefficient calculator
- Symmetry Boundary condition for Fluid flow simulation in Ansys Discovery
- Discovery – Defining new material
- Ansys Discovery: Topology Optimization
- Discovery Quick Tip- Understanding Contour Settings
- How to apply bolt Pretension in ANSYS Discovery?
- Discovery Quick Tip- How to Export to Fluent
- Discovery Quick Tip- Applying Thermal Conductance
- Structural Simulation using Bolt Idealization
