April 5, 2023 at 2:32 pm
FAQParticipant“Fluent does second order interpolation to get the node values from the cell/face values. CFDPost uses first-order interpolation. This leads to slight differences in the node values.To get a closer match between Fluent and CFDPost please use tui command /display/set nodewt-interp no This forces fluent to use the first order interpolation and then the results are comparable.” This has got implemented from Fluent 18.X For Fluent 17.x and before version this solution is not applicable.
- Skewness in ANSYS Meshing
