Customer has found the vulnerability in Microsoft Foundation Class Library in both v19.2 and v2019R1 and wants to know if there is a patch to correct it.
March 17, 2023 at 9:01 am
FAQParticipantAccording to MS11-025: Description of the security update for Visual C++ 2010 Redistributable Package: April 12, 2011, the files that are impacted by this vulnerability are from version 30319.415. The 2010 redistributables we install system-wide for our products are version 40219.01. This should not be an issue.
