Customer has Ansys 10.0 installed on Windows XP SP2. He is able to read in his model but when he uses any option, he gets the following error message: Error: bad screen distance “0.25i”
March 17, 2023 at 9:01 am
FAQParticipantIn this case, it had to do with locale settings. User should try setting the numbers to use a decimal instead of a comma, or change to U.S. locale entirely to see if that resolves the problem.
