Currently, if you run Fluent from within Workbench and save pictures during the solve through the Execute Commands window, the created files are deleted the moment the calculation completes. Why does this happen and how can I prevent it?
Tagged: 19, fluent, fluent-post-processing, fluid-dynamics, General
May 15, 2023 at 8:32 amSolutionParticipant
Please refer to the attachment to access the solution. Keywords: save, image, activities, corruption, delete
1. 2053366.pdf
- Skewness in ANSYS Meshing
- How can I select interior faces and other entities that are inside the model?
- Error: Update failed for the Mesh component in Fluid Flow (Fluent). Error updating cell Mesh in system Fluid Flow (Fluent). View the messages in the Meshing editor for more details.
