Tagged: acp, acp-pre, ansys-mechanical, chassis, composite, composite materials, Formula Student, formula-sae, fsae, FSAE Car, Monocoque, roll-cage, rosetts, stackups, Student Team
June 6, 2022 at 9:30 am
Watch & LearnParticipantIn this video, you will learn how to create fabrics and add structural stackup from composite materials and add rosettes for the different parts of a chassis. For any questions and support, join the ANSYS Student Community: https://studentcommunity.ansys.com/
- Does ECAD trace mapping support more than one type of trace material (usually copper) in the same layer?
