General
General
Creating Lines of Intersection
    • FAQFAQ
      Participant
      This command automatically splits at the intersection of the created mesh. To access this tool, go to Boundary > Remesh > Intersect All Face Zones. By using this command, it is possible to create one line of intersection at a time to split the boundary. Be careful when using this command if you are trying to create lines of intersections when there are many boundaries, as this is very time consuming.
