Created 2D axy symmetric mesh in ICEM CFD and while importing the same in Fluent 2D, error comes as ‘Error at host: Build Grid: Aborted due to critical error. Error at Node 0: Build Grid: Aborted due to critical error. Error: Build Grid: Aborted due to critical error.’
March 17, 2023 at 8:59 am
FAQParticipantFor axysymmetric mesh, Fluent has few conditions which are given below axis of rotation should be x-axis cartesian coordinates used in the geometry and y = 0 is the axis line.
- Skewness in ANSYS Meshing
