June 6, 2022 at 10:51 am
Watch & Learn
ParticipantIn this video we will talk about how to define named selections for a group of entities based on certain criteria, like location or size. This can be useful for large models with a number of surfaces that need to be grouped together in one named selection for the purpose of applying boundary conditions. Selecting them one by one can be very tedious and time consuming.
- How to reverse surface normal in SpaceClaim?
- How to Change the Direction of the Normal Vector of the Internal Face?
- Create Sections in Meshing
- Tip on exporting geometry in Parasolid, STEP format from DesignModeler
- ANSYS ICEM CFD: Basic Blocking
- ANSYS Workbench: Decomposition and Hex Meshing – Part I
- ANSYS Fluent: Watertight Geometry Meshing Workflow
- How can I create a 2D section from a 3D model in SpaceClaim ?
- How do you turn a rectangular surface mesh into a triangular surface mesh?
- What is the difference between patch dependent meshing and patch independent meshing?
