Convergence issues in Fluent for a model with a periodic repeat interface with conformal periodic BCs. What can I do to correct this?
August 25, 2023 at 12:16 pm
SolutionParticipantPlease see attached document. It shows correct order of defining periodic repeats. Keywords: periodic repeat
1. 2047057.pdf
- Skewness in ANSYS Meshing
