Tagged: Altium Designer, ARTWORK, bottom overlay, ECAD translation, FR4, layer stack manager, ODB++, pcb, PCB layers, silkscreen, siwave, stackup, top overlay, vias
July 4, 2022 at 7:00 am
Watch & Learn
ParticipantThis video compares the artwork in Altium with its translated version in SIwave. Some key components in the PCB are identified in Altium and are also located in SIwave. Side by side comparison of the boards in Altium and Ansys also help you review the vias and other aspects of the geometries. ANSYS Electronics software is the premier, integrated solution for electromagnetic field, circuit, systems and multiphysics simulation and analysis.
- I got “I/O error when reading design” error message when opening an AEDT project with HFSS 3D Layout designs after a system crash. How should I proceed to recover my project?
- ANSYS HFSS: Creating 3D Components
- How to Export S-Parameters from HFSS 3D Layout/HFSS 3D Designs ?
- Error: Extracta view creation failed; extracta run failed: Create process failed with error 2: Could not find application extracta.exe.
- How to Set “Non-Model” Property to an Object in 3D Layout
- How to Create Bondwires in 3D Layout ?
- ANSYS HFSS: 3D Layout Cut Out Sub-design – Simulation and Post Processing
- ANSYS HFSS: 3D Layout Model from a Cadence Board File
- How to export a design from HFSS 3D Layout to HFSS 3D Classic?
