August 7, 2024 at 6:33 amSolutionParticipant
In this article we will compare materials with the different normalized parameters for optimization of hip joint design with holes by performing Structural analysis using Ansys Discovery 2024 R1.
Please refer the attached document which demonstrates innovative workflow based on material workflow and simulation driven design. Materials for the stem part of the hip joint were simultaneously studied, simulated, and optimized by following simple and connected procedures.
Download the Simulation files from here to follow the steps in the document.
- Ansys Discovery: Topology Optimization
- Discovery: Porous media coefficient calculator
- Ansys Discovery- Intake and Exhaust Fan for Fluids
- In-Depth – Fluids Simulation using Ansys Discovery
- Thermal Analysis of Heat Sinks with Ansys Discovery
- Structural Simulation using Bolt Idealization
- Discovery Explore: How to retain a certain portion of the geometry in topology optimization?
- Ansys Discovery: Activating Beta Feature
- Discovery Analyze Mode – Unable to view or change material properties.
- Discovery Refine mode – Viewing mesh
