Tagged: 18, HFSS - SYS, hpc, HPC/Parallel, Installation/Licensing/Systems
June 5, 2023 at 7:05 am
FAQ
Participant1. Create the /var/tmp directory if missing 2. Check the permissions of the /var/tmp directory by running: ls -l /var | grep tmp You should get something like the following: > ls -l /var | grep tmp drwxrwxrwt 2 root root
