June 5, 2023 at 7:05 am
FAQParticipantIf ANSYS Mechanical is installed: {install_path}/v180/ansys/bin/anshelp180 If ANSYS Mechanical is not installed: {install_path}/v180/Tools/mono/Linux64/bin/mono {install_path}/v180/commonfiles/help/HelpViewer/ANSYSHelpViewer.exe –language en-us Also applies for R17.x, R16.x and R15.x.
