April 5, 2023 at 2:32 pm
FAQParticipant1. To remove the units : You can create a customer field function. Once you display customer field function units wont be displayed. 2. Border around the color map can removed by using the TUI command : display set windows border no 3. To remove contour name display. Just remove the “Contour Name” option is contour display panel as blank. This is topmost option on left of the panel.
- Skewness in ANSYS Meshing
