August 25, 2023 at 12:15 pm
Solution
ParticipantIn CFD post Iso volumes can be created using Location -> Volume option. There are different methods to create volumes – Sphere, Iso volume, From Surface, Surrounding Node. In some instances, need exists to clip this volume based on certain other criteria such between a range of global coordinate. This solution explains the method to clip iso-volumes based on coordinate criteria.
1. 2049069.pdf
- Skewness in ANSYS Meshing
- ANSYS Fluent: Introduction to the GEKO Turbulence Model Part I
