Tagged: 18.2, fracture, mechanical, static, structural-and-thermal, structural-mechanics
June 5, 2023 at 7:05 am
FAQParticipantThe current implementation of the CINT command does not utilize DMP. Thus, DMP will help with overall solver time, but will not directly improve the solver time associated with the CINT calculations. Development is exploring implementing DMP with the CINT command, but this effort may get implemented in future version.
