September 26, 2022 at 9:44 am
FAQ
ParticipantIn Discovery 2020 R2, there are a couple of options through which you can change the visibility of bodies from transparent to opaque or vice-versa.
1. From View Arc panel
The View Arc panel is located at the bottom left corner of the interface. In this panel, toggle the Visibility button to change the visibility of selected bodies.
2. From Right Click Options
In the Structure Tree or Model Tree, right click on the body and select Transparent or Opaque option.
- Surface to solid creation in SpaceClaim
- FAQ – Share Topology is now available in Discovery 2021 R2
- Ansys Discovery – Working with Components
- Changing the visibility of bodies from transparent to opaque or vice-versa
- Quick Tips for Volume extraction in SpaceClaim
- Split Face in SpaceClaim
- Ansys Discovery: Automatic External Volume Enclosure
- Discovery Quick Tip- How to update your geometry from a source CAD File
- Stitch Faces & Split Edges Tools in SpaceClaim
- Creating Shell Geometry from Solid in SpaceClaim
