June 6, 2022 at 8:45 am
Watch & LearnParticipantIn some cases, it is required to run the simulation with a different setting for the first stage and then switch to a different setting at a later stage. Sometimes such a change is required due to simulation stability considerations and sometimes it is needed to capture a physical phenomena in the application. In this video, we will see how to do that using Fluent text user interface commands.
- Skewness in ANSYS Meshing
