CFX Solution Update fails with error “Update failed for the Solution component in CFX….CFX did not produce a results file…”
Tagged: 18.1, cfx, fluid-dynamics, General - CFX, solver component update, workbench
June 5, 2023 at 7:05 am
FAQParticipantWorkbench gives the error:” Update failed for the Solution component in CFX. The CFX Solver for system CFX did not produce a results file. Detailed information can be found in the output file for the run.” This error could be from a CFX-Pre setup that forces a .res file to not be written which is an invalid setup. In CFX-Pre go to Output Control > Results tab. Ensure that Option is set to Standard, Essential, or Selected Variables. Setting the Option to None will prevent the .res file from being written which will cause this error.
- Skewness in ANSYS Meshing
