CFX Launcher crashes with multiple error messages of dlls not found – libCUEGuiApplication.dll , libCUEGuiUtilities.dll , libCUESystem.dll , libCUECClParseUtilities.dll
March 17, 2023 at 9:00 am
FAQParticipantThe error messages also say Reinstalling the program might fix this problem. Installation logs do not show any related entries in install.err, installation was successful. Please try renaming these folders: – %appdata%Ansysvxx – %localappdata%Ansysvxx – .cfx folder under C:Users
vxx is the folder associated with the particular version of CFX that is crashing
