CFX 2021R1 partitioner fails with the errors Unable to assign product revision id. An error has occurred in cfx5solve: The ANSYS CFX partitioner exited with return code 1.
March 17, 2023 at 8:57 am
FAQParticipantThis error will occur if the Ensight 2021R1.1 patch has been installed. Workaround Linux cd {ansinsdir}/v211/commonfiles/globalsettings cp relinfo.xml to relinfo.xmlensight vi relinfo.xml :1,$s/EnSight 2021/EnSight2021/g :wq Windows cd /d “C:Program FilesANSYS Incv211commonfilesglobalsettings” copy relinfo.xml to relinfo.xmlensight notepad relinfo.xml ctrl+H Find What:”EnSight 2021 R1.1″ Replace with:”EnSight2021 R1.1″ Replace All Cancel File/Save File/Exit
- Skewness in ANSYS Meshing
