CFX 2019R3 products will launch, but an error message pops up: /app/ansys194/v194/CFX/bin/linux-amd64/Launcher.exe: /app/ansys194/v194/tp/qt/5.9.6/linx64/lib/libjpeg.so.62: no version information available (required by /app/ansys194/v194/tp/qt/5.9.6/linx64/lib/libQt5WebEngineCore.so.5) OR: viewer_ogl.exe: /app/ansys/v195/tp/qt/5.9.6/linx64/lib/libjpeg.so.62: no version information available (required by /app/ansys/v195/tp/qt/5.9.6/linx64/lib/libQt5WebEngineCore.so.5) /app/ansys/v195/CFX/bin/linux-amd64/ChartViewer.exe: /app/ansys/v195/tp/qt/5.9.6/linx64/lib/libjpeg.so.62: no version information available (required by /app/ansys/v195/tp/qt/5.9.6/linx64/lib/libQt5WebEngineCore.so.5)
Tagged: 2019 R3, cfx, CFX - SYS, Installation/Licensing/Systems, N/A, Product Specific Issue, QT
January 25, 2023 at 7:28 am
FAQParticipantThe error is due to a problem with the Quicktime (qt) libraries for CFX. The library is not corrupt – it just does not publish version information and Qt outputs warnings about it. This affects versions 2019R2 and R3. It is harmless in interactive mode, and can be bypassed there, but it will disrupt the flow of batch scripts because of the popups.. (We are aware of the issue and it was addressed in 2020R1.) The workaround is to copy a replacement for libjpeg.so.62.0.0 over from release 2019R1 or from the /usr/lib64 directory on the machine. 1. Rename /v195/tp/qt/5.9.6/linx64/lib/libjpeg.so.62.0.0 to libjpeg.so.62.0.0_old. 2. Copy the equivalent file from /v193/CFX/tools/jpeg-6.2/linx64/lib/ or /usr/lib64 to /v195/tp/qt/5.9.6/linx64/lib/.
