March 17, 2023 at 8:58 am
FAQParticipantWhen the Singhal cavitation model is run in Fluent, incorrect volume fractions are calculated in CFD-Post if the .cas, .dat file are used. If a .cdat file is used, the volume fraction plots agree with Fluent post-processing. The solution therefore is to export a .cdat file from Fluent and read that into CFD-Post instead of the .cas and .dat files.
- Skewness in ANSYS Meshing
