CFD-Post and CFX-Pre 2019 R1 throws error when trying to open on a system accessed through Remote desktop – signal 11 was caught: segmentation violation comm::error: GUI Interface : waitInput – Unexpected end of transmission from GUI
Tagged: 2019 R1, black, blank, cfd-post, CFD-Post - SYS, cfx, graphics, Installation/Licensing/Systems, Remote Display
March 17, 2023 at 1:11 pm
SolutionParticipantAdd the system environment variable: QT_OPENGL=desktop to redirect the Qt to use OPENGL libraries from the native desktop.
1. 2062565_solution.pdf
